• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    New Member
    Accepted Solution
    Selective surface in Solar Radiation Model
    121 Views, 1 Replies
    01-04-2013 04:27 AM
    I am trying to simulate a solar collector in Simulation CFD and I do not know hot to define a selective surface material.
    A selective surface material such as the black coating used in solar thermal systems has a high solar absorbance (0.90) and low emissivity (0.2). However, simulation CFD does not take into account absorption and considers emissivity = absorptivity, which are quite different in selective surface.
    Any method to properly simulate a thermal collector in Simulation CFD?
    Please use plain text.
    Product Support
    royce.abel
    Re: Selective surface in Solar Radiation Model
    01-09-2013 08:09 AM in reply to: MiguelVentive
    Just some information for the observer to this post.
    Selective surfaces take advantage of the differing wavelengths of incident solar radiation and the emissive radiation from the absorbing surface:
    • Solar radiation covers approximately the wavelengths 350 nm...4.000 nm; UV-Avisible and near infrared (NIR - or IR-A plus IR-B)).
    • Thermal infrared radiation, from materials with temperatures approximately in the interval -40..100°C, covers approximately the wavelengths 4.000 nm...40.000 nm = 4 um...40 um; The thermal infrared radiation interval being named or covered by: MIRLWIRor IR-C. (wikipedia)
    In Simulation CFD we don't integrate absorption and emission across wavelengths. We assume "grey" body properties. So emissivity averaged over wavelengths and absorption averaged over wavelenghts. We also assume that the radiation is diffuse ( no angular dependance ). For instance we cannot do mirrors accurately because of this assumption.  Since the selective surface design works over different wavelength you are not going to be able to accurately model this in Simulation CFD
    What are you to do?  I think the best approach for you would be to use a black collector approach setting the emissivity to 1 for the solar collector materials.  Did you come up with a better approach?
    There are 3 areas that our radiation model does not address:
    Angular dependence
    Wave length dependence
    Attenuating media effects (gas participating in absorbing radiation energy)
    To make enhancement request please use this site!
    http://forums.autodesk.com/t5/Simulation-CFD-IdeaStation/idb-p/82
    Royce
