Revit architecture 2012 CFD 2012
I have both Revit Architecture 2012 and CFD 2012,
I first installed the CFD 2012 and then Revit Architecture 2012.
however the add in for CFD 2012 appeared not in revit architecturesuite 2012.
what is the cause and what can I do?
Or is there another way to get a file from Revit Architecture in CFD 2012?
Royce_adsk
When installing your CAD package after you installed CFD, you will need to run the program CFDconfig.exe.  This is located in your install directory and should setup new CAD tools to work with CFD.
-Royce
Royce.Abel
Technical Support Manager
It works thank you
