• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Active Member
    Revit architecture 2012 CFD 2012
    186 Views, 2 Replies
    04-03-2012 11:07 AM
    I have both Revit Architecture 2012 and CFD 2012,
    I first installed the CFD 2012 and then Revit Architecture 2012.
    however the add in for CFD 2012 appeared not in revit architecturesuite 2012.
    what is the cause and what can I do?
    Or is there another way to get a file from Revit Architecture in CFD 2012?
    Please use plain text.
    Product Support
    royce.abel
    Re: Revit architecture 2012 CFD 2012
    04-10-2012 01:52 PM in reply to: markkolk
    When installing your CAD package after you installed CFD, you will need to run the program CFDconfig.exe.  This is located in your install directory and should setup new CAD tools to work with CFD.
    -Royce
    Active Member
    04-11-2012 12:52 PM in reply to: markkolk
    It works thank you
