• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Member
    Question about Symmetry
    126 Views, 2 Replies
    09-10-2012 01:16 PM
    I have a model with several solid and fluid objects and when divided along a symmetry line it creates several solid and fluid surfaces including the heat source surface; i.e. the heat source is also divided along the symmetry line.  When I use the symmetry boundary condition, do I need to apply the boundary condition to all surfaces or only the fluid surfaces?  I think the answer is only the fluid surfaces based on my understanding of the symmetry boundary condition, but I need some clarificaiton to be sure.
    Also, can symmetry be used to divide a compact thermal model object; i.e. my heat source is a CTM rather than just a a solid obejct, so do I need to apply symmetry to the compact thermal model surfaces as well?
    BN
    Please use plain text.
    Active Contributor
    marco.mueller
    Re: Question about Symmetry
    09-19-2012 12:03 AM in reply to: brandonnoska
    you'll only need the fluid faces. Also the thermal resistances of the CTM's have to be doubled (if they are cut in 2 halfs) to get the same results as for the full model.
    Member
    10-09-2012 08:06 AM in reply to: marco.mueller
    Thanks.  I did not realize that I needed to cut the Rjc in half.  I did know that you have to cut the power by 1/2, but not the Rjc.
