Autodesk Simulation CFD
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Omit constructi on surfaces created in Inventor from Simulation ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have created a 3D model where I used an ergonomically shaped surface to extrude fins to (Extrude>To Next). I need to do a thermal analysis of this model so I have imported it into Simulation 2013 from Inventor 2013. The problem is that the surface I used to create the fin extrusions is showing up as a volume/part that Simulation is trying to deal with. I don't want the surface in the Simulation model. I just used it to create the shape in Inventor.
How do I get rid of the surface in Simulation or, at the very least, prevent it from being imported in the first place?
Thanks!
Mike
Re: Omit constructi on surfaces created in Inventor from Simulation ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I know for sketches you can just turn off the visibility and it won't be imported. See if that works for surface.
If that doesn't work, you might have to use the delete surface body function to eliminate it.
-Royce
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the tip. I'll try that.
