• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Member
    No Simulation CFD button in Revit
    286 Views, 9 Replies
    10-13-2012 11:45 PM
    I am unable to launch SimulationCFD from within Revit as no SimCFD button appears in Revit.
    I have tried the workaround here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19973972&linkID=18154757
    But there is no .addins file in the folder specified.
    I am using educational license of SimCFD 2013 and Revit 2013 on windows 7 64 bit. Revit was installed after SimCFD -does that make a difference? The launch button does appear in Inventor.
    please help as I would like to demonstrate to my students the integration between BIM & CFD
    Please use plain text.
    Product Support
    wildej
    Re: No Simulation CFD button in Revit
    10-14-2012 01:05 PM in reply to: shroe
    Try running SimCFDconfig.exe (right click and run as admin)
    Jon Wilde
    Product Support Specialist
    Member
    10-14-2012 06:24 PM in reply to: wildej
    Hi Jon,
    Thanks for your reply.
    I've tried this and when I get to the dialogue box to select CAD system, all the CAD options except Fusion 2013 are greyed out. Unclicking Fusion 2013 doesn't make them active.
    It appears have a "student license" which I didn't realize is different from an "educational license" could this be the reason?
    Product Support
    wildej
    10-15-2012 02:06 AM in reply to: shroe
    Files are now located in the marked solution of this forum post.
    Maybe you needed to run the CFD install as admin (with a right click) and this folder could not be added? Worth a go possibly although try this first.
    Jon Wilde
    Member
    10-16-2012 01:22 AM in reply to: wildej
    Hi Jon,
    This worked using the manual workaround mentioned in my first post.
    Thanks a lot for your help.
    Product Support
    wildej
    10-16-2012 02:25 AM in reply to: shroe
    Perfect, thanks for letting me know.
    Jon
    Jon Wilde
    New Member
    10-28-2012 12:54 PM in reply to: shroe
    I am having the same issue, can someone upload the .addin file again or cut and paste the text.  The dropbox link to the ,addin file is dead.  Thanks
    Product Support
    wildej
    10-29-2012 02:16 AM in reply to: shroe
    Jon Wilde
    New Member
    10-29-2012 06:23 AM in reply to: shroe
    Thank you very much for your fast help.  This worked and I am all set.
    Product Support
    royce.abel
    11-02-2012 06:22 AM in reply to: MSahm
    Please reference the support center solution on this topic.  There is a download link in the article if you do not have the folder available to you.
