- Mute
- Permalink
- Report
I am interested in using the parallel meshing option. Wiki help indicates the following.
To improve meshing performance, the Autodesk Simulation CFD mesher leverages multiple computing cores. This reduces the amount of time required to generate large meshes, and better utilizes high performance computing hardware.
To enable multi-threaded meshing, enable this flag in the Flag Manager
mesh_multicore
The argument, n, is the number of cores to be used by the mesher.
In order to use this feature, do I have to have any additional license? If yes, how can i get that easily? Does Cloud solution uses this option if its enabled in my model set-up?
VD
