• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Accepted Solution
    Meshing Error while using training file "Exhibit Hall.cfz"
    139 Views, 4 Replies
    11-04-2012 05:51 PM
    I am newbie to CFD Simulation 2013. I recently tried self-help with the Exhibit Hall file on CFDesign.com. However, it keeps crashing at the meshing stage. Everytime I click Select All-> Preview to see a preview of my mesh, Simulation CFD crashes. If I click Solve, the same error occurs.
    I've attached my file within this post. Could someone please point out where my error is? Thank you.
    Please use plain text.
    Product Support
    wildej
    Re: Meshing Error while using training file "Exhibit Hall.cfz"
    11-06-2012 08:10 AM in reply to: kaiwei
    Are you running on a local drive?
    Could you attach the cfz file, this we can open and can try to replicate the issue here.
    Jon Wilde
    Product Support Specialist
    Autodesk, Inc.
    Distinguished Contributor
    11-13-2012 05:43 AM in reply to: kaiwei
    Kaiwei,
    Try to go here:  http://www.cfdesign.com/OnlineHelp/2013/Test-Drive/AEC/AEC-getting-started.htm
    and download the zip file of the cfx files through link at the top. This model geometry can be meshed without problems.
    I am aware of another link somewhere (perhaps from the offline documentation) which perhaps you are currently using. In that model, the geometry of the man sitting on the bench is difficult to mesh because of sudden sharp cornered surfaces where his pants terminate and shoes start! The mesher fails at that surface hence you can't see the preview.
    Let me know if this solves.
    Cheers
    OJ
    11-14-2012 01:02 AM in reply to: OmkarJ
    Hi OJ,
    The link you provided is where I downloaded the original file from. All the steps in the tutorial are working up till the meshing stage. I will try re-downloading the file to see what happens. Thank you.
    11-14-2012 01:06 AM in reply to: kaiwei
    Just so you know, I was in a mood of some fancy animations yesterday and I tried the same cfz file out. And it worked for me.
    Cheers
    OJ
