- Mute
- Permalink
- Report
Using 2012 Simulation CFD, I noticed a serious issue with the Mesh Refinement Regions.
If I go to Mesh Size > Regions and set three different regions (Region 1, 2 and 3, say with 3 different mesh sizes), I see the corresponding mesh sizes when I click on the different regions from the Step 1: add region listbox. If I click OK to close that window and then tries to go back to the Mesh Refinement Regions, all the corresponding mesh sizes have a value of zero! Visually, the mesh sizes are stil represented with the different node spacing but the mesh size values all show zero. This is a rather annoying especially if the user does not write down mesh sizes on a piece of paper. There is no way to tell what the mesh sizes are, other than a rather time-consuming, trial-and-error method to reconstruct these refinement regions.
Is this a bug and can this be fixed soon?
By the way, is there any chance of having a key-in input for the refinement regions (instead of using click-and-drag only)? The key-in input would be more precise and time-saving, especially when dealing with 3D models and many refinement regions.
Thanks!
