Autodesk Simulation CFD
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
License problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Mac address on the license server has been changed.
What should been done to fix it?
Re: License problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If it is a virtual machine, hard code the license file in your virtual NIC back to match your LIC file or you will continually have the same problem. If it is a physical machine and you changed the network card or motherboard, then you should probably just get a new license file generated to reflect the change.
Please call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=97
1-800-551-1490 > Option 1 (English) > Option 2 > Network
You will need to provide your serial number and new MAC of the license server.
You will get better responses in the network licensing forum for these types of requests. Thanks!
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
Re: License problem
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
It is a license server hos Danfoss that has got a new MAC adress.
I need new license fil for our Program
See Attachement
Sveinn
Edited by
Discussion_Admin
Rephrase the problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Changes were made to license server here at Danfoss causing that the license does not work. I can not create a new license file on the website since it has been done on this contract.
Can I get permission for a new license file on this agreement (110000434892)?
Sincerly
Sveinn
Edited by
Discussion_Admin
Re: Rephrase the problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I went ahead and registered this seat for you. You should have it in your email now.
I will also PM you the license.
