• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation CFD
    Active Member
    sveinn
    Accepted Solution
    License problem
    397 Views, 4 Replies
    02-27-2012 09:28 AM
    Mac address on the license server has been changed.
    What should been done to fix it?
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: License problem
    02-28-2012 11:20 AM in reply to: sveinn
    If it is a virtual machine, hard code the license file in your virtual NIC back to match your LIC file or you will continually have the same problem.  If it is a physical machine and you changed the network card or motherboard, then you should probably just get a new license file generated to reflect the change.
    Please call Autodesk Product Registration and Authorization:
    http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
    1-800-551-1490 > Option 1 (English) > Option 2 > Network
    You will need to provide your serial number and new MAC of the license server.
    You will get better responses in the network licensing forum for these types of requests.  Thanks!
    Active Member
    sveinn
    Re: License problem
    02-29-2012 12:17 AM in reply to: TravisNave
    Hello
    It is a license server hos Danfoss that has got a new MAC adress.
    I need new license fil for our Program
    See Attachement
    Sveinn
    Edited by
    Discussion_Admin
    Active Member
    sveinn
    Rephrase the problem.
    02-29-2012 11:09 PM in reply to: TravisNave
    Changes were made to license server here at Danfoss causing that the license does not work. I can not create a new license file on the website since it has been done on this contract.
    Can I get permission for a new license file on this agreement (110000434892)?
    Sincerly
    Sveinn
    Edited by
    Discussion_Admin
    *Expert Elite*
    TravisNave
    Re: Rephrase the problem.
    03-01-2012 02:59 PM in reply to: sveinn
    I went ahead and registered this seat for you.  You should have it in your email now.
    I will also PM you the license.
