• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    gauravsuri
    Accepted Solution
    Launching CFD from within Inventor
    331 Views, 2 Replies
    03-20-2012 02:14 PM
    Hello
    Does anyone have experience with setting up Inventor so that Simulation CFD shows up in the top menu? It has dissappeared for me.
    Thanks in advance,
    -Gaurav Suri
    Please use plain text.
    Employee
    derrek.cooper
    Re: Launching CFD from within Inventor
    03-20-2012 09:59 PM in reply to: gauravsuri
    hello.. in the install folder is a utility called SimCFDConfig.exe, run that and it should notice Inventor is installed and will place the necessary files where you need them. If that doesn't work, may want to ping support and they can give you the manual file copying method.
    Product Support
    apolo.vanderberg
    03-22-2012 06:30 AM in reply to: gauravsuri
    Assuming this is properly matched 64bit Inventor 2012 and 64bit CFD 2012, you can manually run the following to try manually setting up the launcher.
    Navigate to:
    C:\Program Files\Autodesk\Simulation CFD 2012\Launchers\Inventor\
    and (if Win7 right-click "Run as Admin") on the
    InventorLauncher.bat
