- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been trying to simulate a simple laminar flow in a pipe, however the pressure drop is resulting to be much higher than the analytical value. my Reynolds number is approx 2000, so i have been selecting laminar flow, and ticking the fully developed when selecting the flow rate at the inlet. The solution monitor was put to tight, choosing Advection 2. I have tried both the solution both with automatic mesh using 5 enhancement layers; as well as with manual mesh using 32 nodes on surfaces and 16 nodes on the volume and 5 enhancement layers. however they are both resulting to the same solution which is much larger than the simple analytical value. comments or thoughts? thanks! rob
