• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    matthew.brown
    Re: Inviscid Analysis
    01-18-2012 03:03 PM in reply to: matthew.brown
    Royce,
    I do.  We have been avoiding using it though because it has been very problematic for us. I can run this in 2012 overnight if you think it will make a difference.
    Please use plain text.
    Product Support
    royce.abel
    01-18-2012 03:04 PM in reply to: matthew.brown
    Just checking so that if I do some test on my end I can give you a share file to try out on yours.
    -Royce
    Product Support
    royce.abel
    01-18-2012 03:11 PM in reply to: royce.abel
    Can you give more detail on what you are looking for in the results?
    -Royce
    matthew.brown
    01-18-2012 03:32 PM in reply to: matthew.brown
    Royce,
    We are comparing pressure coefficient and velocity ratio distribution.    I have attached the published results for your reference.
    Product Support
    royce.abel
    01-19-2012 05:28 AM in reply to: matthew.brown
    Matt,
    Here are my results from last night.  Do they look reasonable to your expectations?
    -Royce
    matthew.brown
    01-19-2012 06:10 AM in reply to: matthew.brown
    Royce,
    This is basically what I was seeing.  This really isn't very similar to a potential flow solution though.  There would not be low velocity regions on the airfoil surface (indicating separation), rather the flow would be attached and tangent all along the wall.  The problem is probably too basic for this software to handle.  This isn't too bad though.  It will still give us something close, I think.  Thanks for the effort!
    Product Support
    royce.abel
    01-19-2012 06:22 AM in reply to: matthew.brown
    Matt,
    One last thing for you to checkout.  I turned on the quick forced flow solver.  When Quick Forced Convection is enabled, the flow is computed using a potential flow computation that is complete in one iteration.  When there is no heat transfer boundary conditions present, the heat transfer portion of the analysis is skipped.
    -Royce
    matthew.brown
    01-19-2012 06:25 AM in reply to: matthew.brown
    Royce,
    PERFECT!!!  This is exactly what I was trying to do.  Thanks!
    -Matt
    New Member
    RitaSchnipke
    01-19-2012 06:28 AM in reply to: matthew.brown
    You should be able to run a potential flow solution using the "Quick Forced" option on the "Solve-Physics" widget. You don't need to set any thermal conditions. This should give you a potential flow solution to your problem.
    Product Support
    royce.abel
    01-19-2012 07:24 AM in reply to: matthew.brown
    Matt,
    Here is my share file.  If you could share your results on how they compare to the published results, that would be excellent!
    Royce
