Autodesk Simulation CFD
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Inviscid Analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Royce,
I do. We have been avoiding using it though because it has been very problematic for us. I can run this in 2012 overnight if you think it will make a difference.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just checking so that if I do some test on my end I can give you a share file to try out on yours.
-Royce
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you give more detail on what you are looking for in the results?
-Royce
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Royce,
We are comparing pressure coefficient and velocity ratio distribution. I have attached the published results for your reference.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Matt,
Here are my results from last night. Do they look reasonable to your expectations?
-Royce
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Royce,
This is basically what I was seeing. This really isn't very similar to a potential flow solution though. There would not be low velocity regions on the airfoil surface (indicating separation), rather the flow would be attached and tangent all along the wall. The problem is probably too basic for this software to handle. This isn't too bad though. It will still give us something close, I think. Thanks for the effort!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Matt,
One last thing for you to checkout. I turned on the quick forced flow solver. When Quick Forced Convection is enabled, the flow is computed using a potential flow computation that is complete in one iteration. When there is no heat transfer boundary conditions present, the heat transfer portion of the analysis is skipped.
-Royce
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Royce,
PERFECT!!! This is exactly what I was trying to do. Thanks!
-Matt
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should be able to run a potential flow solution using the "Quick Forced" option on the "Solve-Physics" widget. You don't need to set any thermal conditions. This should give you a potential flow solution to your problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Matt,
Here is my share file. If you could share your results on how they compare to the published results, that would be excellent!
Royce
