• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Valued Contributor
    Inventor - Launch Active Model very slow
    178 Views, 5 Replies
    09-12-2011 07:43 AM
    I've got a 250 part assembly that I am trying to Launch to CFDesign 2012 from inventor 2012. It takes about an hour before I have to kill the process! I seem to be getting hundreds of "Executing Edit Attributes" messages at the bottom of Inventor.
    Any ideas?
    Please use plain text.
    Employee
    derrek.cooper
    Re: Inventor - Launch Active Model very slow
    09-12-2011 08:03 AM in reply to: DWhiteley
    Hi Dave.. An hour seems longer than I would have expect. But, each of the part attribute data is being written prior to launch, so that is the messages you are seeing. We do that so that we can leverage associativity and some of the automation to track the parts location and material data etc.
    How much memory do you have on your machine?
    A quick test would be to solve as an ACIS (*.sat) and read it in direct. This will by-pass the attribute writing and will be faster, however, it will also not allow you to leverage associativity.
    We can take a look at the model to give you a better idea. It will fall under NDA, of course. Would be a good test model to see what we can do to speep up the process.
    derrek
    Valued Contributor
    09-12-2011 08:16 AM in reply to: derrek.cooper
    I have 8gb RAM Derrek. I'll try using SAT to see if that helps. Thanks for your fast reply.
    Valued Contributor
    09-12-2011 08:48 AM in reply to: derrek.cooper
    I tried uisng SAT but got a licence error - ****!!!!
    Employee
    derrek.cooper
    09-12-2011 06:34 PM in reply to: DWhiteley
    Dave.. if this is still an issue, ping me in the AM and I can work to give you a temp license to get you going
    derrek
    Valued Contributor
    09-13-2011 02:52 AM in reply to: derrek.cooper
    Thanks for the offer Derrek, but we're going to order the relevant NFR today.
    Dave
