Message 1 of 26
03:42 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am also facing this exact problem. I installed Autodesk Simulation CFD 2013 as stand alone but when I start the application, the software seems to look for the network licence. FYI, the machine initially had LMTools installed for other Autodesk Software, I don't know if there is any relation to this. What might be the issue?
thank you for the solution.Now I am able to activate the liscense.
but when launching cfd simulation it has stopped working.
please help me i actually need urgently
The interface crashes? Or does it give an error?
You said when launching , are you launching a model frmo CAD to CFD? Or just opening the UI on its own?
Can you give me some details on the graphics hardware you're using?
When you installed this you did (for Vista / Win7) right-click and "Run as Admin" even if you are an Administrator?
Apolo
My guess to the solution would be covered in this up and ready article:
Also make sure that 'TabletInputService' or 'Tablet PC Input Service' is disabled in your services list in Windows.
-Royce
i couldnt resolve the issue.please help me. i have attached the image of the problem
actually i unistalled the autodesk and then i again installed it.now its working fine
thank you very much dude
now the problem is when i am launching autodesk cfd simulation from solid works it is not even responding
Could you post your log file?
It is located here
C:\Users\username\AppData\Local\Autodesk\Simulation CFD 2013\Simulation CFD.log
Royce
When testing the launching from Solidworks follow these two steps first
1) Need to launch from a local drive. Launching from the network can cause issues.
2) Test with something simple like a block first.
-Royce
i am sending the log file
even though i try with the blocks, i couldnt launch it.
actually when launch the autodesk cfd simulation in active mode in solid works it is not responding.
Hi
Have tried to install and run CFD with other Adesk software. Tried everything you have mentioned here and start even a topic ( http://forums.autodesk.com/t5/Installation-Licensing/Cannot-initialze-License-manager-ADLM-startup-f... ) and did everything is mentioned there. Nothing works for me so PLEASE HELP:
Today I installed a new HD with fresh windows7 installation and first Software is CFD. I attach some pictures and logs please se if you can help me.
Hi again,
As you cad upload only 3 files here is the rest.
