• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Re: Installation Problem - Help me
    07-03-2012 02:29 AM in reply to: royce.abel
    actually i unistalled the autodesk and then i again installed it.now its working fine
    Please use plain text.
    07-03-2012 02:31 AM in reply to: apolo.vanderberg
    thank you very much dude
    07-03-2012 07:55 AM in reply to: apolo.vanderberg
    now the problem is when i am launching autodesk cfd simulation from solid works it is not even responding
    Product Support
    royce.abel
    07-03-2012 08:05 AM in reply to: hareesh.kalyan
    Could you post your log file?
    It is located here
    C:\Users\username\AppData\Local\Autodesk\Simulation CFD 2013\Simulation CFD.log
    Royce
    Product Support
    royce.abel
    07-03-2012 08:07 AM in reply to: hareesh.kalyan
    When testing the launching from Solidworks follow these two steps first
    1) Need to launch from a local drive.  Launching from the network can cause issues.
    2) Test with something simple like a block first.
    -Royce
    07-03-2012 08:16 AM in reply to: royce.abel
    i sending the file.plese look into it thank you,
    07-03-2012 08:17 AM in reply to: royce.abel
    i am sending the log file
    07-03-2012 08:39 AM in reply to: hareesh.kalyan
    even though i try with the blocks, i couldnt launch it.
    actually when launch the autodesk cfd simulation in active mode in solid works it is not responding.
    mh
    Active Member
    mh
    07-04-2012 05:42 AM in reply to: hareesh.kalyan
    Hi
    Have tried to install and run CFD with other Adesk software. Tried everything you have mentioned here and start even a topic ( http://forums.autodesk.com/t5/Installation-Licensing/Cannot-initialze-License-manager-ADLM-startup-f... ) and did everything is mentioned there. Nothing works for me so PLEASE HELP:
    Today I installed a new HD with fresh windows7 installation and first Software is CFD. I attach some pictures and logs please se if you can help me.
    mh
    Active Member
    mh
    07-04-2012 05:43 AM in reply to: hareesh.kalyan
    Hi again,
    As you cad upload only 3 files here is the rest.
