• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Installation Problem - Help me
    502 Views, 25 Replies
    06-30-2012 03:42 AM
    i have istalled with stand alone licence
    I installed Network licence manager
    Please use plain text.
    Active Member
    Re: Installation Problem - Help me
    07-02-2012 02:39 AM in reply to: hareesh.kalyan
    I am also facing this exact problem. I installed Autodesk Simulation CFD 2013 as stand alone but when I start the application, the software seems to look for the network licence. FYI, the machine initially had LMTools installed for other Autodesk Software, I don't know if there is any relation to this. What might be the issue?
    Product Support
    apolo.vanderberg
    07-02-2012 08:29 AM in reply to: ilyasramdzan
    Have the two of you looked at the following Knowledge Base Article?
    ADLM Startup Failure
    07-02-2012 12:47 PM in reply to: hareesh.kalyan
    thank you for the solution.Now I am able to activate the liscense.
    but when launching cfd simulation it has stopped working.
    please help me i actually need urgently
    Product Support
    apolo.vanderberg
    07-02-2012 01:29 PM in reply to: hareesh.kalyan
    The interface crashes? Or does it give an error?
    You said when launching , are you launching a model frmo CAD to CFD? Or just opening the UI on its own?
    07-02-2012 01:36 PM in reply to: apolo.vanderberg
    the interface crashes.either i launch from solid works or launching by double clicking the icon autodesk simulation cfd 2013.
    Product Support
    apolo.vanderberg
    07-02-2012 01:39 PM in reply to: hareesh.kalyan
    Can you give me some details on the graphics hardware you're using?
    When you installed this you did (for Vista / Win7) right-click and "Run as Admin" even if you are an Administrator?
    Apolo
    07-02-2012 01:42 PM in reply to: apolo.vanderberg
    ya i did by right clicking. hardware: 4gb RAM, 1GB ATI graphic card,
    Product Support
    royce.abel
    07-02-2012 02:40 PM in reply to: hareesh.kalyan
    My guess to the solution would be covered in this up and ready article:
    http://upandready.typepad.com/up_and_ready/2012/06/autodesk-simulation-cfd-2013-crashes-at-startup.h...
    Also make sure that 'TabletInputService' or 'Tablet PC Input Service' is disabled in your services list in Windows.
    -Royce
    07-02-2012 11:41 PM in reply to: royce.abel
    i couldnt resolve the issue.please help me. i have attached the image of the problem
