Autodesk Simulation CFD
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How is the space automatica lly filled?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How is the empty space automatically filled with a fluid volume when it is brought over from Inventor like in this video?
Re: !!!! How is the space automatica lly filled? !!!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi jrm,
It is a boolean process, which only works if the model is 100% sealed. The advantage of utilisnig this vs using the 'Void Fill' function in CFD, is that we have control over the lengths of the inlets and outlets - ensuring a nice developed flow from the inlet and no recirculation over the outlet.
Jon Wilde
Product Support Specialist
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My model was 100% sealed and it did not do it automatically. Is there a setting in CFD 360 for auto fill?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, it would/should do it automatically, unless there is something very complex that it could be struggling with?
Or if there is a tiny gap somewhere. From experience it is often the latter.
If there is a leak, to find it you could place the entire model in a box - within CFD using the Geometry tools.
Suppress everything apart from the air, apply a P=1psi internally and a p=0 externally and use and ISO surface to identify the leakage path.
Jon Wilde
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I performed the leak test to this video
No leaks show. I did fill the void manually, but I suspect the same thing that resulted in the automatic fill failure is boogering my analysis results.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please could you attach a cfz/support file?
Jon Wilde
