• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Active Contributor
    marco.mueller
    Get element count for mesh adaption
    135 Views, 3 Replies
    05-23-2012 12:32 AM
    is there a quick possibility to see the mesh element count for all scenarios created via mesh adaption, except from activating them manually and checking the status? Seems that there are no *.st-files saved any longer?
    Marco
    Please use plain text.
    Product Support
    royce.abel
    Re: Get element count for mesh adaption
    05-29-2012 12:14 PM in reply to: marco.mueller
    Hi Marco,
    Do you see all the mesh counts in the output window?  I believe they are all there if you scroll up.
    The solver text files are missing and I will make sure that a defect gets logged.
    -Royce
    Active Contributor
    marco.mueller
    06-06-2012 02:36 AM in reply to: royce.abel
    Hey Royce,
    thanks for that! Of course they are visible, but only if the design study is opened.
    Marco
    Product Support
    royce.abel
    06-06-2012 02:32 PM in reply to: marco.mueller
    Yeah, otherwise you will need to go into each status file and extract the data manually.
    When running adaptation the UI should be left open anyways.
