Autodesk Simulation CFD
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Flow paths / particle traces
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there a way of producing particle traces with the surface as the start point? Whenever I select the surface, it shows the history of particles before they reach it, not afterwards.
Am I doing it wrong?
Re: Flow paths / particle traces
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Excellent Question!
When working with particles traces there are basically two different types. Traces that have mass and traces that don't.
When you are using massless traces (which is the type you are using now), this is actually defining where you want the trace to go through at the plane where you placed your seed points. So, as you noticed the trace will still start from the inlet and work towards the outlet, but it will go through the seed points that you positioned on your plane.
If you wanted to model the traces starting at the location of your seed points, try turning on massed particles traces. When defining your massed particles make sure that it has a density that is the same as the fluid and the radius is small. This should allow you to start the traces at your seed point and it will then progress towards the outlet.
Give that a try and let me know how it works out for you!
-Royce
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the advice, all sorted!
