• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    New Member
    First simulation help;
    132 Views, 0 Replies
    03-15-2012 12:15 PM
    When i run the simulation it gets past verifying the model and in analysing where i get the following  warning: Warning! quit for zero loading:
     Ive read some other posts with similar problems  and have solved many issues already to get this point....
    I have attached the ipt file.
    I defined the input velocity (both cylinders on one side)  and inlet/outlets on the other. I have tried meshing it finer, and have excluded the inlet/outlet surfaces as well as prescribed velocity surfaces from the mesh.
    The only other problem i think i could have is I am unsure fully how to set up the simulation, and the add/row/column and what it all means. I kind of just based it off of others/tutorials.
    It doesn't always save, but im using water as the fluid material.
    Thank you for your help
    My email is brandonSlien@gmail.com as another way to contact me.
    Please use plain text.
