• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    New Member
    Accepted Solution
    Export CFD Created Volume to solidWorks/ few other questions
    125 Views, 1 Replies
    06-19-2012 11:44 AM
    Is it possible to create a volume using the CFD tool and export that to solidworks for editing. Or can I edit within autodesk if I only have a simulation key, not the CAD software. In detail, the problem is i want to model a centrifigul pump and I want to eliminate the filets on the water without changing the tube shape. Also I want to use the valute casting to create the volume and than delete it in the CFD but when I click remove it stays, also I surpress it and it stays, just slashes the name bar. Any suggestions?
    Chad
    Please use plain text.
    Product Support
    royce.abel
    Re: Export CFD Created Volume to solidWorks/ few other questions
    07-02-2012 02:27 PM in reply to: cpierce223
    Hi Chad,
    It is not possible to export geometry from Simulation CFD.
    You might want to explore Inventor Fusion for geoemtry simplification.
    -Royce
