• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Active Member
    Drag coefficient on naca 2415
    230 Views, 2 Replies
    10-26-2012 06:24 PM
    I am calculating lift and drag coefficient on naca 2415..
    the resulted lift coefficient is good but somehow the drag coefficient is not close to the experimental result
    can anyone help me
    i am simulating using :
    rng model, and advection 5, for 3232 iteration
    the resulted ift coefficient is 0,21 (0,20 for published experiment's result)
    the resulted drag coefficient is 0,014 (0,007 for published experiment's result)
    the model used in simulation is 2d model, and the equation used to calculating lift and drag coeff is
    F =0,5.p.v2.a
    a = (referenced area, for 2d model i am using the chord length as the referenced area which is 1 m)
    i have attached the attachment, please correct me if i am wrong
    Please use plain text.
    Active Member
    Re: Drag coefficient on naca 2415
    10-28-2012 11:21 PM in reply to: achmad0170
    no answer ???
    Product Support
    royce.abel
    11-05-2012 07:05 AM in reply to: achmad0170
    achmad0170,
    You would need to attach the support .cfz share file for anyone to assist.
    Royce
