• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Doesn't save the results
    146 Views, 2 Replies
    05-29-2012 03:47 AM
    Hi I have a CFD 2013 student edition.If after I exited the program after a simulation, when I load the simulation again It doesn't load also the results of the simulation.
    Is this because of the license ?
    Vlad Martian
    Please use plain text.
    Employee
    derrek.cooper
    Re: Doesn't save the results
    05-29-2012 03:56 AM in reply to: romar_ro
    Hi Vlad.. This should have nothing to do with the license.
    Where is the original CAD geometry coming from and how are you launching it into SIMCFD? You might want to post a support file (File>Save>Share File) to the forum and maybe someone can test it on their end.
    The commercial and EDU versions of SIMCFD are essentially exactly the same.
    05-29-2012 04:37 AM in reply to: derrek.cooper
    Ok, thanks. Anyway I have discovered where I was wrong. Every time I opend the simulation I piked the wrong file (.CFZ instead of *.cfdst).
    Thanks anyway.
