• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    samwicks
    Display Viewport Performance
    121 Views, 6 Replies
    10-31-2012 05:17 AM
    Hi all,
    I have choppy display performance for large models (Geometry input ~ 1,900,000 Nodes, 7,000,000 Elements, 750 Parts, 6,500 Surfaces).
    For the initial set-up, I get frame rates around 4FPS with a Quaddro 2000. GPU-z indicates the GPU core is working at ~40% capacity. System RAM is at 60% capacity and processors are idle.
    I've tried the same model on a machine with a Quaddro 4000 with identical results.
    For Results display, I have 1 - 2 FPS for a filled cut plane with the Quaddro 2000 GPU spiking to 97%.
    Are other users with large models experiencing similar performance?
    Given the GPU utilisation, would a GPU upgrade help?
    Are there any recommended display drivers for Simulation CFD?
    Thanks all
    Please use plain text.
    Product Support
    wildej
    Re: Display Viewport Performance
    11-01-2012 07:16 AM in reply to: samwicks
    Hi Sam,
    Could you try some flags files to tweak the graphical settings:
    Software Rendering : 1
    Use Dropshadow - I often turn this off
    See if either of those makes a difference
    Jon Wilde
    Product Support Specialist
    samwicks
    11-01-2012 09:24 AM in reply to: wildej
    Hi Jon,
    I've been playing about with the flags today. Is there a surefire way of detemining whether the Software Rendering : 1 flag is working? I've enabled it, removed it and set it to 0 with no noticable difference in performance; likewise drop shadow (although that flag is clearly recognised).
    It's got to a stage where the complete model (with no parts hidden) is responsive, but as soon as I hide a part the performance degrades.
    Product Support
    royce.abel
    11-01-2012 02:19 PM in reply to: samwicks
    Make sure you close down the software and reopen when you make changes to these flags.  Also, make sure these are set in the defaults flags section not the scenario level flags.
    For software rendering if you go to the about button located in the 'get started' ribbon, there is a graphics info section available.  The vendor for software rendering is microsoft instead of your graphics card manufacturer.
    -Royce
    Product Support
    wildej
    11-02-2012 01:29 AM in reply to: royce.abel
    Have you also updated all the graphics drivers fully?
    With Nvidia you can also change the GPU settings, we often choose the CATIA setting for the 3D global settings. Well worth making a change here.
    Jon Wilde
    samwicks
    11-02-2012 07:42 AM in reply to: wildej
    Updating drivers [from old CUDA Dev to latest] and the Catia setting has sped it up massively.
    Many thanks
    Product Support
    wildej
    11-03-2012 03:34 AM in reply to: samwicks
    Pleased to hear that worked :smileyhappy:
    Jon Wilde
