Autodesk Simulation CFD
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Can't use extrude mesh to straight cylinders
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
I am having trouble in using Extrude mesh for one of the models I am doing.
Please have a look at the attached sketch.
Part #4 and #7 are long pipes, with no major gradients, and I want to use Extrude mesh for these. Beware that the axis of part #7 is no along -Y direction but is inclined at 45 deg. to -Y in XY plane.
Here, I can use extrude mesh to part #4, but not to part #7. I tried using sweep and extrusion both to create #7.
The model conforms to all "Extrusion Guidelines" documented on wiki.
#Uniform c/s
#Linear extrusion
#3D
#Uniform surfaces in the direction of extrusion
#Ends parallel
Can someone help please?
Without extrusion the mesh cell-count will increase significantly.
OJ
Re: Can't use extrude mesh to straight cylinders
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Anyone, please?
Regards
OJ
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is no reason why this should not work, although I have seen this occur before, with no explanation. Have you tried modelling Part 7 again?
Jon Wilde
Product Support Specialist
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, I tried extrusion and sweep both and retried. No luck!
Without extrude, the cell-count explodes in those long extensions. This limits the refinement degree at the core region of interest.
BTW, I use multibody modelling to create the flow domain and create solids out of the features in the part model. Then I export these solids as parts into assembly using "Make Components". I don't individually create the parts and then assemble them. This is a more efficient way. Don't know if this information is of any use though.
Regards
Omkar.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Omkar,
Would you like to share the pack and go? I can certainly take a look.
If so, please could you start up a new case in the subscription center and we will see what we can do.
Kind regards,
Jon
Jon Wilde
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sure Jon. I will submit the model through the subscription center. Hope Autodesk honour the confidentiality.
Regards
OJ.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you want me to share cfz file, or cfdst file?
OJ
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Omkar,
Yes, we will always honour our confidentiality agreements. Much better to use a case for this exact reason ![]()
Actually, it would be better to have the CAD, so a 'Pack And Go' from Inventor would be perfect!
Jon Wilde
