• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Distinguished Contributor
    Can't apply fully developed flow
    155 Views, 8 Replies
    12-05-2012 01:09 AM
    Ok, this is painfully hilarious.  I have a perfectly circular inlet but when I try to apply a fully developed flow condition (volume flow), it doesn't let me apply. When I untick the fully developed setting , only then I can apply the boundary condition. Going back to CAD (Inventor 2012), I can measure the diameter of that inlet boundary, meaning that CAD confirms its circularity, which is the requirement of fully developed flow!
    Any thoughts?
    OJ
    Please use plain text.
    Re: Can't apply fully developed flow
    12-07-2012 12:54 AM in reply to: OmkarJ
    Someone, please?
    Active Contributor
    marco.mueller
    12-11-2012 06:56 AM in reply to: OmkarJ
    Maybe the edge is split? Or not perfectly flat?
    12-11-2012 06:59 AM in reply to: marco.mueller
    Thanks, at least someone heard! But how to know if the edge is split? The CAD software confirms the circularity as I can measure the diameter. And Geometry Tools in SimCFD doesn't highlight any concern.
    Regards
    OJ
    Active Contributor
    marco.mueller
    12-11-2012 07:01 AM in reply to: OmkarJ
    go to edge selection method and pick the edge. Then you'll see if it is just one or more...
    New Member
    12-19-2012 05:56 AM in reply to: OmkarJ
    Hallo,
    I have the same Problem OmkarJ described. I can't apply fully developed flow as boundary conditon.
    I'm using a Student Version of Simulation CFX 2013.
    Is this probably the reason why I'm not able to use this function?
    Daniel
    01-07-2013 01:49 AM in reply to: OmkarJ
    Well it's just one edge! I had not been able to apply this boundary condition since ages!
    Regards
    OJ
    Valued Contributor
    01-07-2013 07:31 PM in reply to: OmkarJ
    I suggest you try to export your CAD file to another format, open it in Simulation CFD and apply the fully developed BC.
    I tried directly opening my CAD file in Simulation CFD using the Invertor Add-in and faced the same issue when applying the fully developed velocity BC (cannot press Apply on the quickedit dialogue box). For me, the problem only happens for circular cross sections, I experimented with a square cross section and it works fine(as far as applying the BC). For circular cross sections, I exported my CAD as parasolid text and was successful in applying the fully developed velocity BC. I think there might be a problem with the Inventor translations for circular profiles. The problem did not exist for the 2014 Beta version though.
    Regards
    Ilyas
    01-08-2013 12:59 AM in reply to: ilyas
    I have lodged the case with subscription center. I will update this thread with any remedy suggested.
    OJ
