• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Dan.M
    CF Design 2010 license
    134 Views, 3 Replies
    03-03-2013 06:23 AM
    Anyone here remmembers how 2010 version is licensed? LMX? or LM tools?
    Some kind of explanation will help a lot.
    Dan
    Please use plain text.
    TravisNave
    Re: CF Design 2010 license
    03-08-2013 01:25 PM in reply to: Dan.M
    I believe you can still get a license for 2010 for LMTOOLS.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Contributor
    marco.mueller
    03-11-2013 09:00 AM in reply to: TravisNave
    2010 was licensed with LMTools and LMX, it depends on the build you have.
    Dan.M
    03-11-2013 11:55 PM in reply to: marco.mueller
    Ok, I will check.
    Dan
