• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Member
    Accepted Solution
    16 Core Machine only using 8 Cores
    297 Views, 8 Replies
    11-03-2012 08:36 AM
    I have a dual 8 core workstation that I send jobs with the remote solving feature in CFD.  When I tell it to use all 16 cores it only seems to load the workstation to about 50% or half the cores.  What might I need to change so that it will use all 16 cores.
    Please use plain text.
    Product Support
    royce.abel
    Re: 16 Core Machine only using 8 Cores
    11-05-2012 05:39 AM in reply to: sveenman
    Are you sure it is really 16 pysical cores? Many people get confused when hyperthreading is turned on and task manager says there are 16 cores when really there are only 8 physical cores.
    What are your CPU Hardware Specs?
    -Royce
    Member
    11-05-2012 06:16 AM in reply to: royce.abel
    I talked with our IT guys and they said it was not using hyper threading.  According to properties under my computer it is a Xeon E5-2680 @ 2.7GHz and the task manger shows 16 cores.
    Product Support
    royce.abel
    11-05-2012 06:26 AM in reply to: sveenman
    If you open your resource monitor and review your CPU tab, how many CPUs are listed and how many of them indicated the 'Parked' state?
    Royce
    Member
    11-05-2012 06:37 AM in reply to: royce.abel
    8 of them are listed as parked.  So what does that mean?
    -Steve
    Product Support
    royce.abel
    11-05-2012 07:00 AM in reply to: sveenman
    This means that you have 8 physical cores with 8 virtual cores created with hyperthreading.
    -Royce
    Member
    11-05-2012 07:06 AM in reply to: royce.abel
    Thanks for the help I will let the IT Group know.
    -Steve
    Member
    11-15-2012 05:18 AM in reply to: sveenman
    I have now added a 2nd 8 core cpu to this machine.  When I run a simulation now it uses ~25% of the processors.  So becasue hyperthreading is on that means it is still only using 8 of the 16 actual cores.  What am I missing now?
    Member
    akarlsso
    11-27-2012 05:42 AM in reply to: sveenman
    I remember from an earlier release that in a standard license the solver could use up to 4 virtual cores.
    I dont remember which release this came in but it was the greatest enhancement I've seen so far.
    If this is still the case its likely to be an explanation to why you dont see a performance increase
