Autodesk Seek
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
download family
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1915 Views, 4 Replies
02-09-2009 04:13 PM
Is it possible to download a family file (.rfa) for Revit MEP 2009 and load it to the Revit Architecture 2009 family to use?
I don't seem to be able to do so?
Re: download family
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-10-2009 10:18 AM in reply to:
diesellam
Yes, that is very possible. All RFA files are compatible with all three Revit products, however, they can only be opened in a version of Revit that is the same or higher than the file (no backwards compatibility).
One thing to keep in mind about families created in MEP is that MEP installations have access to “Lookup Tables” (.csv files) which define instance parameters of the family. If an MEP user sends a family to an RAC user without the Lookup Table, the RAC user will still have the values populated, but won’t have access to the file for editing (Lookup Tables are only used for MEP content and are only included in MEP installations). The RAC user could always override the values, but may wonder where the values are coming from since the file is unavailable.
I hope this helps!
Jun
Jun Shim
Product Manager,
Autodesk Seek
jun.shim at autodesk dot com
I hope this helps!
Jun
Jun Shim
Product Manager,
Autodesk Seek
Re: download family
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-10-2009 10:30 AM in reply to:
diesellam
So what's the solution to my problem? Did you look up the attached file I attached in my first post that illustrates the problem?
Re: download family
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-20-2009 01:55 PM in reply to:
diesellam
Diesellam,
I am hearing from the Revit experts around here that the category is not set as expected. They expect the family category to be Duct Fittings in this case by looking at the document. The category is not set from the folder you save the file to, but it is set on the family itself.
The families beginning with M_ (typically for metric content) may have category set to “Duct Fitting” instead of “Mechanical Equipment”. You can check the Duct Fittings node on the Project browser to see if the content was actually loaded, but under a different category.
Does this help?
Jun
Does this help?
Jun
Re: download family
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
diesellam
Diesellam,
Does this help?
Jun
Does this help?
Jun
