• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Seek
    New Member
    Tilt-Up Wall Panels
    1628 Views, 2 Replies
    02-26-2009 09:12 AM
    I'm trying to model a concrete Tilt-Up building in Revit Architecture 2009. The wall panels have a 1/2" caulk gap between them, however when I create the panels with the 1/2" seperation, Revit automatically merges the individual panels into one solid length of wall.
    Is there a way to retain the individuality of each panel without creating it as it's own object and placing it in the model?
    Please use plain text.
    Distinguished Contributor
    Re: Tilt-Up Wall Panels
    04-28-2009 05:47 PM in reply to: nsseals
    Do a search over on the AUGI forums. This topic has been talked about a lot there.
    http://forums.augi.com/forumdisplay.php?f=93
    Chad
    07-15-2009 07:19 AM in reply to: nsseals
    You could try using a curtain wall with custom panels and mullions or you could use a standard wall, ignoring the paneling, and use model lines or wall-hosted families to represent the joints or you could make each panel in the family editor. None are perfect and which you use will depend heavily on what your needs are. If you need to schedule them the model line idea won't work. If you need to dimension each panel apart from the wall (like in a legend view) you'll need to make each of them families. You might consider using all of them at various stages of the design starting with a wall and model lines, moving to curtain walls and panels and finally ending up using families.
