• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Seek
    New Member
    Indexing question
    113 Views, 2 Replies
    04-10-2008 07:51 AM
    We are still using ACAD 2004 and have a large number of DWG files I would like to index, preferably via a Google Mini. From the info I gather Googles' ACAD support ended at version 2002i.
    Furthermore using MS Index it seems I can Index starting with version 2006 and some Add On's (DWG I Filter ??)
    Bottom line is I am not finding any definitive info and could really use some direction.
    Any help would be appreciated.
    Chris
    Please use plain text.
    Re: Indexing question
    04-10-2008 02:33 PM in reply to: chrish100
    Hi Chris,
    Thanks for posting and for the question. I could get you in touch with the right people for this and provided we understand your environment some more, we may be able to get you a solution. If others have a similar issue, we can post the solution back on this forum. Please email me at abhi.singh@autodesk.com and we can discuss.
    Thanks and Best Regards,
    Abhi Singh
    Sr. Product Manager
    Autodesk Seek
    04-21-2008 06:10 AM in reply to: chrish100
    chrish100,
    something I could suggest is to set up an MS Search server. Even the free express edition would work well. If you wish to index the textual content inside the dwg's (text etc.) you will need to purchase the DWG iFilter you mentioned. In my experience, this iFilter did not appear to index the attribute information inside the dwg but was able to pick up on the mtext and text notes. The easiest way to make this all work is to import your DWG's into a Sharepoint list or library. If you simply want to make the files easier to find, you don't have to import them into a sharepoint list but you will not be able to associate other data with them. In this simpler scenario, you can just point to Search Server indexing to the folders/shares you have the files hosted.
    You can also check out BIMworld Library manager. It is an independent product that includes the ability to manage DWG data. I have not found anything that can dig out the meta data of the files. We currently have the need for this with our Revit family library. We have actually created something internally for this.
    One of the great things about the Sharepoint framework is that there is abundant information available as well as many developers that can customize it's functionality for you.
    There are other worksharing/portals available in the open source world as well such as O3Spaces and Liferay.
    Also, remember that Windows desktop Search can provide the ability to index content to make it much easier to find for the end users. This is available with both XP and Vista. Google desktop provides similar functionality.
