Autodesk Robot Structural Analysis
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
unhandled exception when opening item from the sections dialog
- Highlight
- Email to a Friend
Just after clicking the open icon in the Section Properties dialog box, I get an unhandled exception. I have the latest service pack and hot fixes as referenced in another post. HEre is the error info:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.EntryPointNotFoundException: Unable to find an entry point named 'SYS_GetLangAbbr' in DLL 'conf.dll'.
at DRobotSectLblMngr.frmSectionLabelManager.SYS_GetLa
at DRobotSectLblMngr.frmSectionLabelManager.Init()
at DRobotSectLblMngr.Main.MainOnTimer()
at DRobotSectLblMngr.frmTimer.Timer1_Tick(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndPr
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.
RobwinInterop
Assembly Version: 0.0.0.0
Win32 Version: 25,0,0,3774
CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysi
msvcm90
Assembly Version: 9.0.30729.4940
Win32 Version: 9.00.30729.4940
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.
AdWindows
Assembly Version: 3.2.25.0
Win32 Version: 3.2.25.0
PresentationCore
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5442 built by: Win7SP1GDR
CodeBase: file:///C:/Windows/assembly/GAC_64/PresentationCor
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3
PresentationFramework
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationF
System.Xml
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.
AdApplicationFrame
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
RobwinRibbon
Assembly Version: 1.0.0.0
Win32 Version: 25.0.0.3774
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Config
Autodesk.Common.DOptionSetOrganizer
Assembly Version: 23.0.0.0
Win32 Version: 25.0.0.3756
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk
Win32 Version: 2.0.50727.5460 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Window
System.Drawing
Win32 Version: 2.0.50727.5462 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawin
Autodesk.Common.DOptionSetOrganizer.Resources
Win32 Version: 23.0.0.0
Autodesk.Common.DTabControlSelector
Autodesk.Common.DTabControlSelector.Resources
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility
Autodesk.REX.Loader
Win32 Version: 2012.0.0.1769
Autodesk.REX.Framework
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.REX.
Autodesk.Common.AResourcesControl
Win32 Version: 2012.0.0.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.Comm
AREXRobotMngr
Assembly Version: 2012.0.0.1161
Win32 Version: 2012.0.0.1161
Interop.RobotOM
REX.Manager
Assembly Version: 2012.0.0.1769
REX.Engine
Assembly Version: 2012.0.0.1422
REX.Preferences
REX.System
REX.UI.WPF
REX.UI
REX.UI.Forms
Assembly Version: 2012.0.0.1642
REX.UI.Resources
REX.Foundation
REX.System.Resources
REX.Manager.Resources
DRobotSectLblMngr
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Vis
DRobotSectLblMngr.Resources
Interop.syspathsLib
Assembly Version: 5.0.0.0
Interop.IDbRootLib
Microsoft.VisualBasic.Compatibility
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Re: unhandled exception when opening item from the sections dialog
- Highlight
- Email to a Friend
Try to delete files from Windows TEMP dialog and rename your CfgUsr folder.
Cfgusr
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Autodes
Win 7 32- or 64-bit RSAPro:
Has this solved this problem?
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
I will certainly try this and let you know! Thanks!
- Highlight
- Email to a Friend
when you say "temp dialog" do you mean here for windows 7?:
C:\Windows\Temp
or here?:
C:\Users\mbrule\AppData\Local\Temp
- Highlight
- Email to a Friend
In case this doesn't help make screen capture and indicate the icon you press as well as include the viewer opened when you use Help > Robot information commands being in any model with the structure in Robot.
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
I tried your suggestion but got the same exact error. I get it when clicking open in the Sections dialog box (the dialog you get when clicking the icon that looks like a red capital letter i). Curiously, I got a popup about an available autodesk update so I click it and it began downloading service pack 5. I was puzzled because I made sure when I created the deploy for this that the latest updates would be included in the deploy. However, there is a download button under the service pack 5 to include and it began showing a green progress bar while it downloads. I thought it would have done this in thd background as it creates the deploy but maybe not. It's possible then that the end user having this issue also doesn't have SP5 for RSA 2012 so I will allow this to fully download and test again on my test box. If it corrects the issue, then chalk it up to lack of an important update. I'll keep you posted.
- Highlight
- Email to a Friend
If this is your situation:
then it has been corrected in HF3 for Robot 2012.
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
the image is a bit too small to see details but installing SP5 resolved that error. i am waiting for the end user who has this problem to try it and get back to me.
- Highlight
- Email to a Friend
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Yup, that's the button generating the error. So far so good after installing SP 5 but I am still waiting to hear back from the end user that it is actually working for him now.
