• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Accepted Solution
    unhandled exception when opening item from the sections dialog
    274 Views, 11 Replies
    11-16-2012 09:36 AM
    Just after clicking the open icon in the Section Properties dialog box, I get an unhandled exception.  I have the latest service pack and hot fixes as referenced in another post.  HEre is the error info:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.EntryPointNotFoundException: Unable to find an entry point named 'SYS_GetLangAbbr' in DLL 'conf.dll'.
       at DRobotSectLblMngr.frmSectionLabelManager.SYS_GetLangAbbr(Int16& lang)
       at DRobotSectLblMngr.frmSectionLabelManager.Init()
       at DRobotSectLblMngr.Main.MainOnTimer()
       at DRobotSectLblMngr.frmTimer.Timer1_Tick(Object eventSender, EventArgs eventArgs)
       at System.Windows.Forms.Timer.OnTick(EventArgs e)
       at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400)
        CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
    RobwinInterop
        Assembly Version: 0.0.0.0
        Win32 Version: 25,0,0,3774
        CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/RobwinInterop.DLL
    msvcm90
        Assembly Version: 9.0.30729.4940
        Win32 Version: 9.00.30729.4940
        CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c/msvcm90.dll
    System
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    AdWindows
        Assembly Version: 3.2.25.0
        Win32 Version: 3.2.25.0
        CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/AdWindows.DLL
    PresentationCore
        Assembly Version: 3.0.0.0
        Win32 Version: 3.0.6920.5442 built by: Win7SP1GDR
        CodeBase: file:///C:/Windows/assembly/GAC_64/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
    WindowsBase
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
    PresentationFramework
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    System.Xml
        Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    AdApplicationFrame
        CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/AdApplicationFrame.DLL
    PresentationFramework.Aero
        Win32 Version: 3.0.6920.4902 built by: NetFXw7
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
    RobwinRibbon
        Assembly Version: 1.0.0.0
        Win32 Version: 25.0.0.3774
        CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/RobwinRibbon.DLL
    System.Configuration
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    Autodesk.Common.DOptionSetOrganizer
        Assembly Version: 23.0.0.0
        Win32 Version: 25.0.0.3756
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DOptionSetOrganizer/Autodesk.Common.DOptionSetOrganizer.dll
        Win32 Version: 2.0.50727.5460 (Win7SP1GDR.050727-5400)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        Win32 Version: 2.0.50727.5462 (Win7SP1GDR.050727-5400)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Autodesk.Common.DOptionSetOrganizer.Resources
        Win32 Version: 23.0.0.0
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DOptionSetOrganizer/en-US/Autodesk.Common.DOptionSetOrganizer.resources.DLL
    Autodesk.Common.DTabControlSelector
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DTabControlSelector/Autodesk.Common.DTabControlSelector.dll
    Autodesk.Common.DTabControlSelector.Resources
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DTabControlSelector/en-US/Autodesk.Common.DTabControlSelector.resources.DLL
    Accessibility
        Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    Autodesk.REX.Loader
        Win32 Version: 2012.0.0.1769
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Loader/Autodesk.REX.Loader.dll
    Autodesk.REX.Framework
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.REX.Framework/1.0.0.0__51e16e3b26b42eda/Autodesk.REX.Framework.dll
    Autodesk.Common.AResourcesControl
        Win32 Version: 2012.0.0.0
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.Common.AResourcesControl/1.0.0.0__ff3304d4f320ee59/Autodesk.Common.AResourcesControl.dll
    AREXRobotMngr
        Assembly Version: 2012.0.0.1161
        Win32 Version: 2012.0.0.1161
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Products/Robot/AREXRobotMngr.dll
    Interop.RobotOM
        CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.RobotOM.DLL
    REX.Manager
        Assembly Version: 2012.0.0.1769
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Manager.dll
    REX.Engine
        Assembly Version: 2012.0.0.1422
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Engine.dll
    REX.Preferences
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Preferences.DLL
    REX.System
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.System.DLL
    REX.UI.WPF
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.WPF.DLL
    REX.UI
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.DLL
    REX.UI.Forms
        Assembly Version: 2012.0.0.1642
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.Forms.DLL
    REX.UI.Resources
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.UI.resources.DLL
    REX.Foundation
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Foundation/REX.Foundation.dll
    REX.System.Resources
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.System.resources.dll
    REX.Manager.Resources
        CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.Manager.resources.dll
    DRobotSectLblMngr
        CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/DRobotSectLblMngr.DLL
    Microsoft.VisualBasic
        Assembly Version: 8.0.0.0
        Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    DRobotSectLblMngr.Resources
        CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/en-US/DRobotSectLblMngr.resources.DLL
    Interop.syspathsLib
        Assembly Version: 5.0.0.0
        CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.syspathsLib.DLL
    Interop.IDbRootLib
        CodeBase: file:///C:/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.IDbRootLib.DLL
    Microsoft.VisualBasic.Compatibility
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic.Compatibility/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.Compatibility.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: unhandled exception when opening item from the sections dialog
    11-19-2012 12:13 AM in reply to: smurgas
    Try to delete files from Windows TEMP dialog and rename your CfgUsr folder.
    Cfgusr
    Win XP:
    c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
    Win Vista:
    C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
    Win 7 32- or 64-bit RSAPro:
    Has this solved this problem?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    11-19-2012 05:04 AM in reply to: smurgas
    I will certainly try this and let you know!  Thanks!
    11-19-2012 05:06 AM in reply to: Artur.Kosakowski
    when you say "temp dialog" do you mean here for windows 7?:
    C:\Windows\Temp
    or here?:
    C:\Users\mbrule\AppData\Local\Temp
    Product Support
    Artur.Kosakowski
    11-19-2012 05:12 AM in reply to: smurgas
    In case this doesn't help make screen capture and indicate the icon you press as well as include the viewer opened when you use Help > Robot information commands being in any model with the structure in Robot.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    11-19-2012 06:56 AM in reply to: smurgas
    I tried your suggestion but got the same exact error.  I get it when clicking open in the Sections dialog box (the dialog you get when clicking the icon that looks like a red capital letter i).  Curiously, I got a popup about an available autodesk update so I click it and it began downloading service pack 5.  I was puzzled because I made sure when I created the deploy for this that the latest updates would be included in the deploy.  However, there is a download button under the service pack 5 to include and it began showing a green progress bar while it downloads.  I thought it would have done this in thd background as it creates the deploy but maybe not.  It's possible then that the end user having this issue also doesn't have SP5 for RSA 2012 so I will allow this to fully download and test again on my test box.  If it corrects the issue, then chalk it up to lack of an important update.  I'll keep you posted.
    Product Support
    Artur.Kosakowski
    11-19-2012 07:02 AM in reply to: smurgas
    If this is your situation:
    then it has been corrected in HF3 for Robot 2012.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    11-19-2012 07:05 AM in reply to: Artur.Kosakowski
    the image is a bit too small to see details but installing SP5 resolved that error.  i am waiting for the end user who has this problem to try it and get back to me.
    Product Support
    Artur.Kosakowski
    11-19-2012 07:26 AM in reply to: smurgas
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    11-19-2012 07:41 AM in reply to: Artur.Kosakowski
    Yup, that's the button generating the error.  So far so good after installing SP 5 but I am still waiting to hear back from the end user that it is actually working for him now.
