• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Product Support
    Re: truss design
    01-08-2013 06:08 AM in reply to: CKDDIZ
    Is there an option in RSA, example 2 bars to be connected as 1?
    Vote here : http://forums.autodesk.com/t5/Robot-Structural-Analysis/Merging-two-bars-into-one-bar/idi-p/3701596
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: truss design
    01-08-2013 06:21 AM in reply to: CKDDIZ
    Do you mean
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Joining-bars-in-RSA2013/m-p/3567934
    or
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Re: truss design
    01-08-2013 06:24 AM in reply to: Artur.Kosakowski
    the first one, got the answer :smileyhappy:
    thanks
    Valued Contributor
    Re: truss design
    01-08-2013 06:37 AM in reply to: CKDDIZ
    Can you please show step by step what changes did you do to the 3d model, :smileysad:
    I see, you applied pinned-pinned releases to the purlins, what else?
    The chords must be continuous or use partial releases, but I don't see in the model you applied partial releases to the chords!!
    Product Support
    Artur.Kosakowski
    Re: truss design
    01-08-2013 06:48 AM in reply to: CKDDIZ
    No, actually they were already defined in the model you sent :smileyhappy:
    therefore I deleted truss bar attribute from them
    That was just the suggestion which you can take or reject. This depends on the expected behavior of the truss node connections and  the final decision is in your hand.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Re: truss design
    01-08-2013 06:52 AM in reply to: Artur.Kosakowski
    :smileyembarrassed: got it
    Valued Contributor
    Re: truss design
    01-10-2013 02:03 AM in reply to: CKDDIZ
    Trying to apply the wind load on a 3D model, getting the following problem
    Product Support
    Artur.Kosakowski
    Re: truss design
    01-10-2013 02:10 AM in reply to: CKDDIZ
    See http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Uniform-planar-load-on-contour/m-p/3030154 (post 4).
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
