• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    Accepted Solution
    truss design
    786 Views, 17 Replies
    08-27-2012 06:19 AM
    hello,
    my question is related to truss design,when the moment release is applied to the truss member during calculations the instability window appears!!! Why does this happen?
    Please use plain text.
    Valued Contributor
    Rafacascudo
    Re: truss design
    08-27-2012 06:32 AM in reply to: CKDDIZ
    You shouldn´t apply releases to the members that have a pinned support as one of their nodes.
    Also ,Instead of using releases you can use "truss bars  only" through geometry/additonal atributes/advanced properties
    Valued Contributor
    Re: truss design
    08-27-2012 07:24 AM in reply to: Rafacascudo
    I tryed to model an example from the truss database selection on two fixed columns, the truss members are moment realesed from the truss table option.
    Still got the stability window during calcs!!
    Product Support
    Artur.Kosakowski
    Re: truss design
    08-27-2012 07:40 AM in reply to: CKDDIZ
    Delete the side posts and replace them with the columns.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Re: truss design
    01-08-2013 01:22 AM in reply to: Artur.Kosakowski
    calculated a truss in 2D in truss structure type (pic 1), exporting it in 3D ( pic 2) getting instability in Y dir.
    Suggestions please!
    Thank you
    Product Support
    Artur.Kosakowski
    Re: truss design
    01-08-2013 01:54 AM in reply to: CKDDIZ
    If you have out of truss plane releases nothing prevent horizontal movement of its elements in this direction. I think you should add some boundary conditions (or redefine the releases) to prevent this from happening.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Re: truss design
    01-08-2013 04:57 AM in reply to: Artur.Kosakowski
    1) using the truss bar option without any bar release, getting the same instability type.
    2) using bar release in X,Z direction only , same instability.
    Trying to solve the roof structure in 3D, how important is the bar offset of the transversal beams (purlins) in this case?
    Do you recommend roof as cladding, and wind load applied on it?
    Product Support
    Artur.Kosakowski
    Re: truss design
    01-08-2013 05:11 AM in reply to: CKDDIZ
    Truss bars are similar to bars with pinned end connections.
    For a 3D structural roof you should keep the chords as continuous (see the attached model). Otherwise you can consider use of partial releases.
     Personally I would not define any offsets.
    This is one of the options but this is going to be your decision :smileyhappy:
    P.S. I have corrected the error of not applying truss bar attribute to one line of posts in the attached model too.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Re: truss design
    01-08-2013 05:47 AM in reply to: Artur.Kosakowski
    Thanks :smileywink:
    Valued Contributor
    Re: truss design
    01-08-2013 06:05 AM in reply to: CKDDIZ
    Is there an option in RSA, example 2 bars to be connected as 1?
