• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    tapered column section
    152 Views, 3 Replies
    01-25-2013 11:05 PM
    hi,
    is there any way to create tepared concrete column section?
    thanks
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: tapered column section
    01-27-2013 11:11 PM in reply to: peter-rc
    If you want to use it in the model for static calculations of a model then there is no problem (you can define a steel section and then change material of a bar in the model) but such sections are not supported for in the RC Column Design module.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Distinguished Contributor
    faisal.aaouatif
    02-11-2013 03:48 AM in reply to: Artur.Kosakowski
    what about dynamic calculations ?
    Product Support
    Artur.Kosakowski
    02-11-2013 04:22 AM in reply to: faisal.aaouatif
    As for static analysis.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
