• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Member
    Accepted Solution
    select bars that has the same section
    126 Views, 3 Replies
    10-23-2012 02:34 PM
    Dear all, I would like to ask you how it is possible to select all the bars having the same section.
    I have the problem of assigning the member type to the elements, in order  to perform the calculations in the design modules.
    I thought the easiest way to assign the correct member type (column, beam, etc...) would be on the basis of their section. For example, if I am able to select all the bars that has a given section, I can assign to all of them a given member type.
    To my knowlege, the only other way is to assign the member type one by one ,using indexes?
    I hope you could give me a suggestion.
    Thank you in advance,
    best, dario
    Please use plain text.
    Distinguished Contributor
    athurD
    Re: select bars that has the same section
    10-23-2012 08:32 PM in reply to: dariocesare
    Hi.
    Please see picture.
    Product Support
    10-23-2012 11:32 PM in reply to: dariocesare
    Also:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Member
    thank you!
    10-23-2012 11:33 PM in reply to: RG_Adsk
    thank you very much!
