• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    ovedmata
    seismic load application?
    363 Views, 3 Replies
    11-28-2011 07:47 PM
    What's the best way to apply a seismic load or wind load to a 3D structure? I've modeled a 3 story buidling, with a non-recatungular geometry, and I'd like to know what the best way to apply the these loads are?
    my wind/snow 2D/3D is greyed out.
    Do I just apply the loads to every member, or  is there a faster way?
    thanks,
    Oved.
    p.s. I keep trying to run a search on this forum and nothing happens. It doesn't work. Any ideas?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: seismic load application?
    11-29-2011 12:03 AM in reply to: ovedmata
    The seismic load is generated automatically after you define seismic analysis cases. Depending on your model you can either define wind load case as loads applied to each of elements or use a cladding (surface) load with automatic distribution of loads to 'supporting' elements. The wind 2D/3D option is in fact based on the cladding load definition and is available for selected climatic codes.
    In case of problems with the search option try to reload the forum site.
    Artur Kosakowski
    Support Specialist
    Product Support
    ovedmata
    12-02-2011 04:07 PM in reply to: Artur.Kosakowski
    "use a cladding (surface) load with automatic distribution of loads to 'supporting' elements"
    Can you elaborate on this? Or is there  a suporting document for it?
    Ive tried adding a cladding contour in the zy plane of the building and the zx, but It just doesn't feel right.
    All help appreciated.
    Thank you,
    Oved
    ovedmata
    12-02-2011 09:28 PM in reply to: ovedmata
    :-) Nevermind. I got it.
    Thank you!! :smileyvery-happy:
