• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    mortel09
    Accepted Solution
    results
    162 Views, 3 Replies
    01-31-2012 02:32 AM
    Hello. I was woundering on what i should do after i have calculated my construction... How can i know if the construction can handle the loads that are on it? Its a easy 3D frame construction...
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: results
    01-31-2012 02:45 AM in reply to: mortel09
    Please try to use the design modules that are incorporate in the program. In fact this is what they are intended for in the first place :smileyhappy:
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    mortel09
    Re: results
    01-31-2012 02:59 AM in reply to: Artur.Kosakowski
    could you give you us a detalied step by step of how you can easly find out if the constructions holds?
    Product Support
    Artur.Kosakowski
    Re: results
    01-31-2012 03:16 AM in reply to: mortel09
    Please refer to the 3rd message from this topic of the forum:
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Tutorials-for-Robot-Structure-analysis/m-p/2...
    The description of the steel design can be found in chapters 2.7, 5.5 and 6.4 of the training manual.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
