• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    New Member
    Accepted Solution
    raft foundation
    339 Views, 4 Replies
    01-10-2013 12:36 AM
    Good morning
    I m learning Robot 2011.
    I m trying to model a raft foundation
    would you please give me the steps?
    Please use plain text.
    Product Support
    Re: raft foundation
    01-10-2013 12:41 AM in reply to: lis2984
    ordinary plate but in thickness defintion add soil elasticity
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    New Member
    Re: raft foundation
    01-15-2013 06:07 PM in reply to: RG_Adsk
    thxs!
    Active Contributor
    Re: raft foundation
    04-22-2013 04:15 PM in reply to: lis2984
    Hi, im also new with the slab foundation and elastic ground..
    I have made this model for a slab foundation, i hate a ellastic coefficient of 25Ton/m3 but i dont think i defined correctly the planar Kz since soil pressure in the result maps goes above 180 T/m2 ( According to soil study Max 25Ton/m2).
    1) Can you pls tell me how to correctly define Kz (it ask for a load above foundation) and Kz=0 when i do it this way.
    2) is it ok to define a kz manually since i have the value.
    3)How can i see the soil pressure correctly, the moment and shear diagrams?? i have seen it in other models but cant find the panel cut tool.
    Thank you for ur help.
    Regards
    Product Support
    Re: raft foundation
    04-25-2013 01:25 AM in reply to: willjvizcaya
    I do not understand your model data. If you know kz = 25 T/m3 so why have you specified kz~3000 T/m3 ?
    Take a look below sw of your slab is 1680 T and it gives pressure 34,46 T/m2 ; soil kz = 25 T/m3 means that if you have load of 25 T/m2 it will be displaced 1m. So in your case you get 1,34m displacement.
    Yes
    Results menu \ Panel Cuts
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
