• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Member
    mail2mr1
    Accepted Solution
    "System.Runtime.InteropServices.COMException (0x80040154)"
    645 Views, 4 Replies
    08-20-2011 12:13 PM
    When I try to make a section selection from the database by opening database sections to get properties by using menu items.. geometry..properties..sections, I receive the following error:
    System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {5C257DA9-418F-11DF-BDA4-002264AF06AC} failed due to the following error: 80040154.
    Entering "continue" does not help.
    Can anyone help me?
    Bill
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: System.Runtime.InteropServices.COMException (0x80040154)
    08-22-2011 04:29 AM in reply to: mail2mr1
    Could you make the screen capture that illustrate this situation please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    dimogrec
    12-14-2011 10:14 AM in reply to: Artur.Kosakowski
    I' m having the same issue with RSA2012 pro 64bit. I also have RSA _pro 2011 32bit installed and i don't have this problem.  I'm running Win7 64bit. In the attachment you'll find a screen capture and a text file with the error details
    Product Support
    Artur.Kosakowski
    12-14-2011 11:39 PM in reply to: dimogrec
    Please download and install the indicated updates from http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    dimogrec
    12-15-2011 12:56 AM in reply to: Artur.Kosakowski
    thanks. It worked
