• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    Jorgew09
    quasi-permanent combinations
    242 Views, 9 Replies
    02-07-2012 02:55 AM
    When I try to calculate provided reinforcement for my beam I get the following error: "There are no quasi-permanent combinations. calculations may be incorect".
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: quasi-permanent combinations
    02-07-2012 03:06 AM in reply to: Jorgew09
    Is it the same issue that has been solved here http://forums.autodesk.com/t5/Autodesk-Robot-Structural/SLS-combination/m-p/3316923/highlight/true#M... ?
    Just try to select SLS:QPR instead of SLS while defining combinations.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Jorgew09
    02-07-2012 03:10 AM in reply to: Artur.Kosakowski
    I have selected SLS:QPR
    Product Support
    Artur.Kosakowski
    02-07-2012 03:19 AM in reply to: Jorgew09
    Please send me the rtd file and indicate which beam you want to design as well as which load cases you wanted to use for the design.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Jorgew09
    02-07-2012 04:08 AM in reply to: Artur.Kosakowski
    I can't send the file, because I can't get the file size small enough, even though i compress it with winRAR. Is there any other way I can send it to you?
    Product Support
    Artur.Kosakowski
    02-07-2012 04:16 AM in reply to: Jorgew09
    Before we try anything else:
    1. Open your file
    2. Delete all other elements from the model but the beam you want to import (do not edit/delete loads or combinations)
    3. Make sure it is supported (add some nodal supports or column if needed)
    4. Calculate model
    5. Check if you have the same problem with combination type
    6. Save the model under a new name and send it (should be small enough)
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Jorgew09
    02-07-2012 04:48 AM in reply to: Artur.Kosakowski
     I want to design the indicated T-beam. Using the Uls combination and SLS:QPR combination
    Product Support
    Artur.Kosakowski
    02-07-2012 05:20 AM in reply to: Jorgew09
    I can't see any problem with doing so. There is no message displayed. Could you make either sequence of screen captures or a small move to show your steps and what happens on your computer please?
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    Jorgew09
    02-07-2012 05:24 AM in reply to: Artur.Kosakowski
    Product Support
    Artur.Kosakowski
    02-07-2012 05:51 AM in reply to: Jorgew09
    The difference is that I'm using v.2012 with SP4 installed whereas you have no SP installed. The SP4 should be available for download at the of this week from http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
    In addition I think you should correct the nestled definitions of combinations
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
