• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    punching capacity of slab without shear reinforcement
    343 Views, 6 Replies
    11-07-2012 07:56 AM
    Verification problem 2 - punching capacity of slab without shear reinf. cant get the right results.
    In verification problem 1 - everything was ok.
    I tried to apply the forces in the node from a node with rigid links to column placement - get get the right results still.
    Can u please help me what am I doing wrong?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: punching capacity of slab without shear reinforcement
    11-08-2012 05:45 AM in reply to: CKDDIZ
    You have different RC code used in your model. I'm attaching the modified file.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    11-08-2012 11:55 PM in reply to: CKDDIZ
    Thank you,
    if I understand correctly,
    the model was OK, but the code was set to user.
    For calculating shear resistance Finnish code SFS-En 1992-1-1 must be used?
    Thanx again
    Product Support
    Artur.Kosakowski
    11-09-2012 12:04 AM in reply to: CKDDIZ
    the model was OK,
    Correct
    EN 1992-1-1:2004 AC:2008
    You can use different code but in such case the slab punching capacity may be different that the one from the reference example which is calculated for SFS-EN 1992-1-1
    Artur Kosakowski
    Support Specialist
    Product Support
    Member
    Jon_wardrop
    05-06-2013 07:23 AM in reply to: Artur.Kosakowski
    Hi I downloaded the Robot model which Artur provided and tried to run it on my machine but I get a different punching shear result,  as shown below. It appears that the deadload from the slab (4mx4mx0.24x24.5 = 94kN) is being added to the 192kN point load. Why is the punching now calculated for 286kN? Is the rigid membrane still working correctly? I have attached the Robot model.
    Member
    Jon_wardrop
    05-07-2013 01:15 AM in reply to: Jon_wardrop
    I think my problem above may be an example of ROBOT seeming to remember previoulsy calculated values and when you think you have re-run the design, you haven't and ROBOT is just presenting the values it previously calculated!
    Whenever I am trying to learn something new in ROBOT this becomes an annoying problem.  I find that to resolve it you need to play around with the model (i.e change some input, re-run the anlysis and then change the input back to original and then re-run).
    Is there any way to "purge " previous results, so ROBOT stops showing old values as results?
    Jon
    Product Support
    Artur.Kosakowski
    05-07-2013 02:33 AM in reply to: Jon_wardrop
    Try to select save without results file type and give the file a new name.
    BTW: Does the following complain sound familiar?  "I have calculated all my project and now I want to make small change to a tiny part of it but I don't want to lose my results that are not going to be influenced by this change" :smileywink:
    Artur Kosakowski
    Support Specialist
    Product Support
