• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    DALHOUMI400
    Accepted Solution
    probleme de modulisation de contreventement en 3d
    138 Views, 3 Replies
    01-14-2013 11:47 AM
    svp comment moduler le contrev pour une charpente en 3d
    les cornieres doivent étre dimentionné pour la traction le pb quand j imposse des treis en traction uniquement toute les combinaisons de charge s 'annule du progremme !
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: probleme de modulisation de contreventement en 3d
    01-15-2013 12:51 AM in reply to: DALHOUMI400
    Automatic code combinations can only be generated for linear static analysis as they are based on results of the previously calculated simple load cases. For non linear analysis you have two options:
    1. Before you change the analysis type to non linear (or define tension only elements) you should generate automatic code combinations and then convert them into manual combinations. The option is available from the combination table as illustrated below:
    2. Instead of generating automatic code combinations you can generate manual combinations in the automatic way. All you have to do is select manual combinations generation in the dialog shown below:
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    DALHOUMI400
    01-15-2013 06:32 AM in reply to: Artur.Kosakowski
    Merci pour votre réponse
    mais quand je lance le calcul le programme me recommande d utiliser l algorithme DSC quand je j active cet aligortime il ya un probleme avec l'excentrement
    est ce je dois annuler l'excentrement ? est si je le fais quelle est linfluence sur le calcul
          merci
    Product Support
    Artur.Kosakowski
    01-15-2013 06:39 AM in reply to: DALHOUMI400
    The DSC releases cannot be defined on bars with offsets as this produces incorrect results. In such case you have to switch the use of DSC off or replace offsets with e.g. rigid links or dummy bars.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
