Autodesk Robot Structural Analysis
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
probleme de modulisati on de contrevent ement en 3d
- Highlight
- Email to a Friend
svp comment moduler le contrev pour une charpente en 3d
les cornieres doivent étre dimentionné pour la traction le pb quand j imposse des treis en traction uniquement toute les combinaisons de charge s 'annule du progremme !
Re: probleme de modulisati on de contrevent ement en 3d
- Highlight
- Email to a Friend
Automatic code combinations can only be generated for linear static analysis as they are based on results of the previously calculated simple load cases. For non linear analysis you have two options:
1. Before you change the analysis type to non linear (or define tension only elements) you should generate automatic code combinations and then convert them into manual combinations. The option is available from the combination table as illustrated below:
2. Instead of generating automatic code combinations you can generate manual combinations in the automatic way. All you have to do is select manual combinations generation in the dialog shown below:
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Merci pour votre réponse
mais quand je lance le calcul le programme me recommande d utiliser l algorithme DSC quand je j active cet aligortime il ya un probleme avec l'excentrement
est ce je dois annuler l'excentrement ? est si je le fais quelle est linfluence sur le calcul
merci
- Highlight
- Email to a Friend
The DSC releases cannot be defined on bars with offsets as this produces incorrect results. In such case you have to switch the use of DSC off or replace offsets with e.g. rigid links or dummy bars.
Artur Kosakowski
Support Specialist
Product Support
Autodesk, Inc.
