• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    saclovitzky
    plate/shell member's shape configuration
    213 Views, 26 Replies
    07-17-2012 03:45 PM
    Is there any command in robot that will change the shape of a wall by means of stretching it( imagine a rectangular wall and you try to move the upper portion only but the lower portion is fixed), the normal way of doing this, is moving/traslating the "nodes" on top and start modelling the walls and you have a slanted wall, but how about if you have rectangular wall and you want to deformed it, moving nodes is not an option(since only nodes will move leaving behind the wall).
    Pls. see attched.
    Please use plain text.
    Moderator
    Romanich
    Re: plate/shell member's shape configuration
    07-17-2012 08:47 PM in reply to: saclovitzky
    Maybe by editing coordinate of plate?
    Active Contributor
    07-17-2012 10:15 PM in reply to: saclovitzky
    Try with graphical edit.
    Select the wall and then locate the corner you want to move. Use zoom and pan for precise selection. Then click with left mouse button on the corner you want to move and drag to a new location.
    Product Support
    Artur.Kosakowski
    07-17-2012 11:40 PM in reply to: sergey.churilov
    Select the wall and then locate the corner you want to move. Use zoom and pan for precise selection. Then click with left mouse button on the corner you want to move; click on it again and drag to a new location.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    saclovitzky
    07-18-2012 01:13 AM in reply to: saclovitzky
    Thanks everybody! But how about if I need a precise location/dimension,ie, 36 mm etc. My twenty story project needs the core walls" tilt" about 52 mm from the top of the 18 th floor(just to give allowance to the effect of posttensioned floors), I am also wondering, if there's a sweeping command that I can used to tilt all the walls that form the core wall in one instant(even the openings will follow as well).
    Regards
    Product Support
    Artur.Kosakowski
    07-18-2012 01:20 AM in reply to: saclovitzky
    Please make a sketch of the existing situation the intended change.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    saclovitzky
    07-18-2012 01:37 AM in reply to: Artur.Kosakowski
    Hello Arthur,
    The intention is to tilt the whole building 52 mm from the top with respect to base.
    See attached.
    REgards,
    Product Support
    Artur.Kosakowski
    07-18-2012 01:47 AM in reply to: saclovitzky
    Try to use the detailed correction.
    Artur Kosakowski
    Support Specialist
    Product Support
    Valued Contributor
    saclovitzky
    07-18-2012 02:12 AM in reply to: Artur.Kosakowski
    How? and what is the purpose of doing that?
    Product Support
    Artur.Kosakowski
    07-18-2012 02:13 AM in reply to: saclovitzky
    Have you looked at the picture I attached to the previous message?
    Artur Kosakowski
    Support Specialist
    Product Support
