panels button
panels button
panels button
I'm using robot structual analysis 2012, and cannot find the panels button. please help?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please make sure you selected the right structure type (e.g. shell rather than frame) using Geometry > Structure type.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Still can't find it..
Artur.Kosakowski
Autodesk Support
Autodesk Support
The position of the button for the default Shell layout is indicated on the attached picture. You can also use the text commands.
Artur Kosakowski
I have attached a print screen, and there is no panels button to see
Artur.Kosakowski
Autodesk Support
Autodesk Support
The layout is the frame one. Use Geometry > Structure type and select Solid and then do this once more and select Shell again.
Artur Kosakowski
